Because the code says so?
Perhaps it's the fact welding tends to remove the required corrosion protection?
Or that improper welding techniques could lead to slag / sharp edges inside the raceway?
I don't have a real answer Steve but to look at another way is why should I weld it when there are so many products designed to support ridge pipe?
Bob
