Was on a service call today and I need a little input from the smart people here.
Situation:Electric range was giving lady a shock when she touched the pot on the stovetop. Measured 40 VAC from the burner surface to the frame. This is a 3 wire setup, with the ground and neutral bonded at the stove. The feed is from 120Y/208.
Could there be any current coming back on the neutral from the elements? I checked the elements, nothing rang out to ground. And it only did it on the 2 larger burners.
It also had a digital clock/timer in it. Could it somehow have cuased current to flow on the nuetral and thus through the frame?
Thanks for any help gentlemen, Gary
