I use my counter tops. Rule # 1 any object permanently on the countertop MUST be capable of being rigorusly cleaned (ie with water). Hence the name "backsplash" for the wall perpendicular to the counter. How long before syrup (insert your fav. sticky substance here) gets between the rubber flange on top and the counter, that's the last time you are opening it without the "power riser" option.
