What about upgrading the wiring ?
Talking about putting in 20 Amps brakers, fine.
it would be a good idea to check the wire size also, as that may be not adequate for the size of the brakers and cause excessive voltage drop under high loads and or possible fires.
A clean, new cable from the switchboard from adequate size would be the best option.
