John,
Thanks for the reply.
My concern is that the connectors for RNC are not tapered and as a result will allow water to get into the meter socket.
Conduit is supposed to drain but, why put a weather head on a riser if we want water to get into the pipe ?
Should RMC be the only permitted riser material because it has tapered threads ?
Alan--
