i did work on alot of tanning bed and they are very picky with voltage rating due large load of ballast and some case heater in there.
i just got done dealt with one machine say 210 volt only so i put a buck/boost transformer to get it right.
by the way dont derate the tanning bed if you do the load figures [ i found out in hard way ]
Merci, Marc
