Iwire, to answer your question, my Fluke 336 meter gives you continuity and ohms on one setting. It also does AC volts, DC volts, AC amps and DC amps with an amp clamp. 600 volts, 600 amps.
I thought I had a decent meter. It's better than the ones I've seen on the job. Joe was kind enough to let me know that it's a middle-of-the-roader on the grand scheme of things. Basically I'm trying to take a de-tuned four stroke enduro out to Carlsbad.
Joe, thanks for your help. What meters would you recommend for someone with a sick mind?
