Your mention of the high leg....
Don't tell me that this motor is high leg to neutral....
This puppy should be wired single phase, hot to hot...the full 240....wild leg then means not much.
If it was wired high leg to neutral... stop that. High legs can swing wildly against neutral since they are affected by the load balance in the 120 V circuits. I wouldn't use it.
