Russ, brought up a good issue here, he may have solved his problem, but i see many under sized raceways out there, as Bob said, "The company I work for is more concerned with progress and passing inspection than worrying about the cost difference between an 18" x 18" can or a 24" x 24" can so I tend to figure big most times."
Working with larger conductors in a small raceway can be tough, but i still see many undersized raceways out there, i can't see the savings, when what you save on the box costs you 4 times over in labor.
