LOW VOLTAGE LIGHTING PLAGUES ME AGAIN.
WHAT ARE THE 96 & 99 CODE ACTUAL REQUIREMENTS FOR LOCATION AND METHOD OF WIRING LOW VOLTAGE 10 / 20W UNDERCAB PUCK LIGHTS.
ROMEX TERMINATED UNDER THE CAB. WIRED TO A CLASS 2 L.V.60W ELECTRONIC TRANSFORMER. 3 X 10W -12V PUCKS ARE WIRED TO THE T/F ALL LOCATED UNDER THE KITCHEN CAB.
A DECORATIVE FALSE BOTTOM THEN COVERS ALL THE WIRING FOR OBVIOUS REASONS OF AESTHETICS.
INSPECTOR SAY THIS DOES NOT COMPLY WITH CODE.
SAME INSPECTION DEPARTMENT THAT WILL NOT ACCEPT REMOTE LV T/F BEING WIRED WHERE THE SECONDARY / LV CIRCUIT WIRES SHARE THE SAME CAVITY OR WALL SPACE?
WHERE DO I GO FOR A CLEAR PICTURE OF DO'S & DON'T ON LV WIRING OF RESIDENTIAL INTERIOR LIGHTING? SORRY TO BE A PAIN!
