Greg, to quote some one do this, first highlite the sentence or paragraph you need then go to edit and copy, you can also right click. Then type including brackets [QOTE] and add the "U" at this point paste your field then type [/ qote] put the "U" in and this will post the field as a quote
Example
mine dont turn out with the horizontal line..
Roger
[This message has been edited by Roger (edited 03-18-2005).]
