... If it's sheetrock that I had to cut for a hand hole,I either keep the piece I cut out,then when done,I put a piece of furring strip behind it,and screw the cut piece to it..(to me,it's better than just leaving a hole in the wall,and it usually looks alittle neater)then I tell them it's up to them to have it spackled over and painted,or I put in a plastic single gang old work box,and put a white blank plate on it,..if esthetics is not a concern.I can't spackle to save my own hide,..so I refer a good dry-waller that I know,or usually the H.O. has their own..
Russ
[This message has been edited by Attic Rat (edited 03-05-2005).]
.."if it ain't fixed,don't break it...call a Licensed Electrician"
