I'm sure glad I found this discussion board.
Is it possible for a hydro meter to run too fast?
Our home seems to use an excessive amount every month even though we try and conserve as much as possible. (3250 kWh in Jan)
Someone told me once that an unbalanced panel could cause this. What the heck is that anyway?
We have a transformer on the pole out front that hums a bit and there is a ground rod laying on the ground beside the pole. Could this have something to do with it?
Thanks in advance.
