People usually have problems because the conductors are too short to hold and/or the stripped ends are not lined up or long enough.
When I do this I strip a little more than what is needed, line them all up, pre-twist, then cut the end off to the proper length. Never had a problem with even more than 6 or 8 #12s and the proper wire nut.
-Hal
