I've got a question.
Part of a Science project involves connection to a 6 volt Battery. It is one from those little Ride-around Jeeps. We have to charge the Battery (hasn't been charged in Years so I'm crossing my fingers)
The problem is that the plugin charger had the wires chewed up by some squirrels that I let squat in the Garage out back. Which way (polarity) should it be connected up?
Now, I know the polarities on the Battery + & - is printed on the top. Can I tell the polarities on the charger with my Fluke meter? When I connect it one way it says "-".
I assume that means the probes are reversed. When it is correct I should be able to tell the polarities of the charger output from the leads, Right? Black would be - ? Red = + ?
Last question, if I know these things, how should it be connected to charge the battery? I thought I remembered from somewhere that they should be connected opposite (+ of charger to - of Battery) Is this correct?
