When installing the new Raintite connectors in a threaded device do you use the rubber washer? On some lights and boxes the female threads start resessed and you can't get but one or two threads but if you remove the washer you can get a good connection. I was taught if it was threaded it was water tight. What are your thoughts? Rod
