I am going to run a dedicated circuit to a hot tub (60 amp) load center/GFCI disconnect.
Questions:
Can I use cable type THHN or do I have to use something like USE? Would this be classified as a service wire when carrying power to the disconnect? Can I run more than just the spa off of the feeders to the spa disconnect?
Thanks,
seems like the fire department might get involved
