They do make such a thing, however most supply houses don't carry them as common stock. Ask for a Bell, Red Dot or Intermatic catalog and they do have some larger ones, that you can order. The common stocked ones are pretty shallow. Some are also made for a special slanted box, simular to a pin and sleeve connector type box.
http://www.hubbellcatalog.com/raco/RACO_datasheet.asp?PN=5784%2D0&FAM=BellWeatherproof&P=7630,7645,5640,5527
[This message has been edited by e57 (edited 10-05-2004).]
