DC motors are better in applications where very wide speed control range is needed, particularly when lots of torque is needed at low speeds. Speed range can be adjusted from zero to full rated speed, or even higher with field weakening.
Lots of old DC motors are still in service, after having the old Ward-Leonard MG set controllers replaced with modern SCR drives.
