Most hydraulic problems are simply worn soft parts like seals.
Usually you can buy a 'kit' of the soft parts and it is simple to take the item apart and replace the seals.
However be careful of spring loaded parts, a Greenlee punch head comes to mind.
If you do not have ways to deal with the spring pressure send the parts out.
Bob
