The frequency could be a problem with some types of electronic timer circuits. Some derive their timing by dividing down the power-line frequency, others use an internal oscillator and aren't affected. Mechanical timers using a 50Hz synchronous motor will run fast on 60Hz of course.
Presumably the original line and neutral wires of the dryer have been properly connected across the two hots?
