OK Scott I will get out of houses.
Many of our commercial customers specify fusible switch gear over breakers.
One of them has a strange policy of sizing the fusible switch one size larger than needed.
If we will be installing 40 amp fuses they ask for a 100 amp switch, 200 amp fuses would need a 400 amp position.
Every fuse we install in their gear has to get fuse reducers.
[This message has been edited by iwire (edited 05-20-2004).]
