...[No thread hi-jacking intended,]...but can/should I use a GFCI receptacle on a 120 volt laundry circuit,.. ie;..gas fired washer/dryer..or does that create problems as well..? I've heard tell that GFCI's don't "like" motor loads,being that when the motor first starts up,the windings create a "faux" short for a split second,and the GFCI see'a that as a ground fault..Is this true..??
Russ
PS..You may now continue with your regular scheduled thread posting..The preceding was a Public Safety Message...
[This message has been edited by Attic Rat (edited 05-07-2004).]
