iwire you go around painting boxes?
that is a good way to do things for you and your company. Most of the time the specs
will say how thay want it done .Like on my job i have to paint all fire alarm boxes
red and also the pipe.What i would like to know is do you give the owner's a copy of what the colers stand for?
As an example all 277 lighting J box covers will be yellow, 120 lighting green
Green is for ground can you paint the box that color? I seen someware that if you
used a green wire nut on hot conductors
that it would not be to code. So would that be saying it is all grounds inside?
