Got a job estimate for a 50a outdoor spa. The run is about 100 ft. I would pipe up out of the panel (outdoor panels here in AZ) down the side of the house to a disconnect, then probably run liguid-tite to the spa. If the spa has a GFI built in or on a cord will I need one in the panel too? I usually do a job like this for around $500 to $600. Wanted to do some price comparing, what would you charge?
Thanks,
Al D
