You are bidding on an E-Booklet. This is very imformative with wiring diagrams and explanation that anyone can understand. Many times when a 3-way switch is replaced the wires are not connected properly and the switch will work on one side and not the other. With several different diagrams, this should cover most situations.
A must have for any electrician.
