It's fine to set your water heater at 150º as long as you have a mixing valve to keep "delivered water" around 120 or less.
And most residential water heaters use one element at a time. Top element has priority and locks ut bottom element until the top of the tank is up to temp.
Most commercial electric water heaters can have all elements on at the same time. Usually ach element is on a different phase.
