Tev, in the box you type the post in, there is a link to the left of the box "*UBB Code is On". This link will provide you with information on posting images, italics, bold type,...
Here is the info for image posting - To add a graphic within your message, just encase the URL of the graphic image as shown in the following example (UBBCode™ is in red).
[ IMG]
http://www.infopop.com/artwork/footer_logotype.gif[/IMG ]
In the example above, the UBBCode™ automatically makes the graphic visible in your message. Note: the "http://" part of the URL is REQUIRED for the [img] code. Also note: some UBB forums may disable the [img] tag support to prevent objectionable images from being viewed.
The [img] and [/img] should not have spaces in them. I added them to prevent the actual image from being posted in this reply.
PS, the panel is a SquareD(right click on the image to get it's URL address).
steve
[This message has been edited by stamcon (edited 09-14-2003).]
