I use a Nikon CoolPix 775. A nicely built unit, that can take a reasonable bit of physical abuse. 2.1 megapixel, compact flash, USB, and a relatively simple menu system for settings, etc. A decent autofocus system, and good quality lens.
Only downside is the battery life. The factory NiCd only lasts an hour or so if you aren't religious about turning it off between shots. The "power save" mode doesn't seem to save much power!
It won't run anything as common as AA cells, but it can take a relatively common lithium camera battery (2CR5), which gives much better life than the NiCd, especially in cold weather.
[This message has been edited by NJwirenut (edited 08-25-2003).]
