I have a small dilema with a customer. They have some puck lights installed under cabinets in the kitchen. The little sockets on the lights are junk, which I found out when trying to replace the lamps. The pucks need to be replaced. #1 They are recessed in the botton of the cabinet and most manufacturrers prohibit this. #2 The wiring is lamp cord run through the wall which the NEC prohibits. I don't want to replace them and I think I will explain why but I know I will look like a jerk to them (which is fine). What would you guys do?
