I see you're hedging your bets over another thorny issue in these photos by having one ground up and the other ground down!
Trumpy,
You might not be aware that the term
duplex is also used in America to refer to two homes constructed as a single building. These are what would be called "semi-detached" in Britain -- Not sure what you call them down under.
