If this is a grounding electrode conductor, it must be bonded to the EMT at both ends. See 250.92(A)(3)
If this is an equipment ground, generally speaking, it has no business being run outside of the raceway or cable that contain the circuit conductors.
Few things are harder to put up with than the annoyance of a good example.
