Using Joe's instructions you can load images from other places. Place you mouse over the picture you want, right click on it select properties and you will get the address for that picture, in this case the address is
http://www.aifittings.com/images/b2_800ima.gif By inserting this address between the UBB codes that Joe used you will get this.
You can use the edit button on anyone's post to see what the code looked like for whatever they did, you can not change someone's post only look at it. You can have images from many sources.
[This message has been edited by iwire (edited 03-09-2003).]
