hotline i do agree with you about those compact breakers like ge breakers which it do bring me back some memories about it. it gave me a sour taste with it especally try to get use the duplex verson to run 220 or 208 volts on 2 pole set up some case it ran only 110 volts . and what more i try to check the panel board what is the limit of number of breaker it can take.
btw yeah ch breaker do make duplex single pole breakers and sq d also BUT sd d have 2 versions so watch out due the stab cam below the breaker
merci marc
