Reno:
When these rails are installed originally, there is compliant working space for utility workers (meters/CTs), and access to the means of disconnect. That also provides 'working space' of 36" minimum.
Access to the electrical equip is on either end, as at least one 'end' is open for access. In the pic, you can see an opening in the rail.
