I used them once several years ago and wasn't comfortable with the design.
Also, as caselec said there is a question about feed-through wiring.
BTW,
I find 410.11 somewhat ambiguous in that it seems to permit feed-through wiring if the the fixtures are operating together, even if not identified as such. Does this restriction only pertain to wiring on a different part of the lighting circuit?
