TW, the type you described is officially called a "hybrid" meter.
Roughly five years ago, electronic meters became cheaper than electromechanicals for polyphase service. For 1ø, basic single-rate electromechanicals are still essentially a commodity item.
One advantage of microprocessor-based units is that many are configured with an alternate display mode that will read accurate per-phase voltage and current at the metering point.
