Hi,
Do most PVC manufacturers recommend using PVC cleaner PRIOR to gluing the conduit?
I have a lot of Underground duct banks that are just being wiped off and glued...
I say the manufacturers installation instructions should be followed.
I am being told if the pipe is not under pressure you can just wipe off the dirt and the glue acts as a solvent.
Thanks
Greg
