I saw this while out and about today and just had to share it... I don't currently have pictures, so I hope a description will suffice. frown
Picture this, a PB installed about 10ft up a wall in a public space... that in itself is not a problem, provided certain provisions are made... but... that's the only thing about the install that's OK. Directly below the board, there is a small, unprotected ledge, about 8ft wide and 18in deep... no railing or anything.
But wait, it gets worse! Below that ledge is a set of double doors which control access to an employees-only area of the store.
So, in summary:
-Panelboard with insufficient frontal clearance
-No fixed means of access
-Unsafe access in general
Thoughts? Have you seen worse? eek
