http://www.cooperindustries.com/con...ntal/pv-fuses/solar-pv-fuse-14x51mm.htmlBussman shows 10,000 Amps as the interrupting rating.
Never forget: PV cells saturate current flow with a bolted short at much lower levels than rotary induction devices.
15, 20, 25 & 32A
Notably, these fuses are designed towards the European standard; hence the 32A type.
