Has anyone came across the problem with the "in-use" covers fitting in the outlets fittings that vinyl siding men put in for them? I always have to "rig" it up to get the in-use covers to fit inside the opening. I have to use long 6/32 screws and a spacer to get it to come out far enough for the cover to open, then caulk it to make it look decent and to keep water out. Surely there's a manufacturer that's come across this problem. Thanks, Steve
