The number one issue is that the graphite molds are sensitive to relative humidity.
Best results occur IF you pre-heat the mold in your oven the night before.
This drives out the humidity/water...
Then the mold does NOT explode upon the heat of burning...
Aluminum and Magnesium powdered metal...
Which is what drives the whole equation.
ERICO has competition.
Check around...
