Originally Posted by gfretwell
I am arguing with an installer about the T103 timer.
This thing is clearly in a NEMA 1 case (indoor only) but there is nothing in the instructions (sticker) or on the box that says so. In fact the box says
Parking lot lighting
Billboard lighting
Commercial lighting
Pools/Spas/Fountains
Electric Water Heaters
Outdoor Lighting
How can you enforce 110.3(B) when the label is wrong?
You are the AHJ,Correct? in your opinion,and the fact that you have a model number for the NEMA 3 unit,What more do you need?
What is the model # installed? Make a call. I understand your trying to be fair..That's commendable....But....
Many devices can be used to control many things.Where the controlers are located is the issue.
