Originally Posted by renosteinke
Look behind the plate ... you'll likely find 25 (EDIT: I mean 300 - thanks G!) Ohm antenna wire.
Obsolete? Absolutely - espacially since all TV has since gone digital.
With the proper connector you could jack that into your DTV converter box or flatpanel and get a decent signal.
Cliff
