MVR,
Almost any fixture line will have high quality all the way down to poor quality fixtures. Halo is made by Cooper, and they may be trashy fixtures, but Cooper has other higher quality fixture lines. Lithonia, and Lightolier have good lines of fixtures.
I've never used RUUD before, but one idea I like about them is, you can buy factory direct. That could be good or bad. I have a feeling that Hotline has used them, and likes them. As Hotline mentioned, use their engineering dept. They can help you get the lighting that you need. Most "reps" for quality fixture lines that I've worked with in the past will do the same thing for you.
Call a supply house in your area, and ask for some help. They'll usually do it.
Regards,
Doc
