There is 5 voltage rated class on the gloves.
Class No. / AC test voltage / Max Voltage
00 / 2500V / 500V
0 / 5000V / 1000V
1 / 10000V / 7500V
2 / 20000V / 17000V
3 / 30000V / 26500V
IIRC there is one or two more class gloves which I don't have the listing with me ATM
However I have few diffrent class gloves in my invetory the most common one I use most case is class 0 or 00 depending on the area I have to dealt with it.
The costwise it will be 50€ and up depending on what class and other related items you will need.
Rubber protector { the main glove }
Leather glove
inside liner { there is summer or winter verison }
Carry bag for the set as I mention above.
As far for takeing care the gloves myself and Mike Trumpy explain the prodcure for testing and make sure you keep the gloves clean and properly use it and when you get done or not using for while put it away quick to keep it clean all the time.
Merci,Marc
