Venice & Washington Blvds, Los Angeles
Near as I can tell, 2x 138KV ckts on top, either 21 or 12KV below that, older 4160V ckt below that. The quad below that feeds from a transformer across the street primaried from the above 4160 and then goes underground,
on the bottom various telecom, cable, etc..
[Linked Image from electrical-photos.com]
Ave 152, Tulare County (rural)
138KV & 12KV on the same arm
Same pole line, where the 12KV begins to run next to the 130KV
This is a more typical pole layout (also on the same road)
