Are those voltage readings actual measurements taken with a DMM, or just the numbers that the program reports?
I have tried a couple of those "system monitor" programs, including one that Intel included with their own motherboard, and ALL of them had serious "issues" with accurate voltage measurements. Not sure what the measurement system uses as a voltage reference, either.
Measure the supply outputs yourself with a good DMM before swapping out the PSU solely on the results of some piece of software. While you are at it, check each DC supply rail with the meter set for AC, to look for excessive ripple. The first thing to go in those power supplies is the filter capacitors drying up...
