I have a problem at my house, and not sure if this is a viable solution...we have Verizon FIOS...all is well, except, i have one run that is approx 200' long...there it splits to 3 tv's...
there is an amplifier on the line already, installed by Verizon, but it's a 15db bi-directional amp...and it barely gave enough signal strength when there was only 1 tv on it...
the picture comes through, but the menu guide and the on-demand features don't work.
So, did a little research and I am going to install a tilt amplifier at the source....my question is this...
if the tilt amplifier doesn't throw enough oomph into the line, can I add a bi directional amplifier at the end of the line (before it splits into the 3 tv's)...or is it only 1 amp per line?
