Results from the Amprobe for site lighting UG fault locations (opens/breaks) can be good, but....practice & patience are required. A few long phone calls to the factory tech helped. Like I said 2nd best. Managed to track a UG burnout to a 2' wide X 4' area, cut the blacktop, dug down & it was almost dead center. Using the Ditch Witch wand, narrowed a similar break to an 12" x 18" area. Both jobs were #4 & #6 AL conductors in PVC & energized.
